3/8 t joint coupon
发表于 2021-9-1 00:38:42 | 显示全部楼层 |阅读模式
hey guys i am trying to get into the lincoln pipe welding class the prerequisite is a 3x12 3/8 v up and oh 4 in 1 pass 4 in 2 pass 4 in 3 pass t joint  my v up isnt too bad but oh needs sum practice the thing is i dont have a dc machine i have an ac machine but i figure i can practice with some ac rod and find a machine to weld up a coupon the parameters are the 6010 is 5/32 and the 7018 is 1/8 th in  any help or tricks on the oh technique  thanks i know some pipe fitters can help memiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:A bit of punctuation would go a long way in understanding  .....Mike
GMT+8, 2025-12-21 14:31 , Processed in 0.107935 second(s), 18 queries .
