Todays Emergency "Fix It" Job
发表于 2021-9-1 00:38:16 | 显示全部楼层 |阅读模式
Got an emergency fix it job today...Center pivot valve for an excavatorthe major O.D. was pitted and grooved from wear and it was leaking hyd. oil by the gallon...2000$$ to have the end chrome plated (.008 under to start)so we went the easy? route.."give it to zap! and let him fix it"oh boy!!  well heres the job start to finish.. the finish O.D. is 5.750+0 -.0005by now its being re-installed......zap!#1..remove "o" rings..Attachment 4152#2 protect the finish with brass strip and tape..Attachment 4153#3..weld with everyones favorite rod 7018 Attachment 4154#4..rough grind with #3 wheel..Attachment 4155#5..finish grind with #1 wheel..Attachment 4156and thats how its done......zap!Last edited by zapster; 12-27-2007 at 05:20 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks for posting the pics.  It's always nice to see the work from a master.  Does the finished surface achieve a seal by slipping into O-rings?
Reply:that i'm not sure of because there is no "o" ring wear from the begining..was kinda sharp lookingbut the tolerance is so close that i'm guessing a high pressure seal thats like a really high performance grease seal  ...zap!Last edited by zapster; 07-19-2006 at 08:43 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice work Zap !John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Thats what i'm talking about!  You are the man.
Reply:Excellent post. More like a class room demo.   Good work.
Reply:WOuw Pretty sexy!Nice Job
Reply:nice job zap Creative metal Creative metal Facebook
Reply:Great work Zap. Always good to see your work.Simonhttp://members.optusnet.com.au/~abba/index.html
Reply:good job ZAPChuckASME Pressure Vessel welder
Reply:It amazes me to see work like that.  Awesome!  Makes IT work look boring.  MM175 MIGCutmaster 38 PlasmaCraftsman 30gal compressor4x6 HF bandsaw1hp HF floor drill pressRyobi Cutoff SawAssorted grindersNot enough time
Reply:nice fix, I have a question on those grinders, like a surface grinder I suppose, how can it hold such a tight tolerence with a rock wheel? Doesn't the wheel wear as you go?  Always been something I wondered, I never used one.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Originally Posted by littlefuzznice fix, I have a question on those grinders, like a surface grinder I suppose, how can it hold such a tight tolerence with a rock wheel? Doesn't the wheel wear as you go?  Always been something I wondered, I never used one.
Reply:Not only is it nice work your approach is clever too.  Taking the time to document the progress of the job and take pictures is a very smart idea.  I know it sounds simply but often I get too entrenched in the process.  I don't know how many times I get a project done and think to myself -- It sure would have been nice to have a "before" picture.  You can really appreciate the work involved when you document the steps.
Reply:thanks everyone for the kudos..hell i have nothing to hide..and kinda enjoy doing posts like this...its not everyday that average people get "up close and personal" with machinery like this...so i'll let everyone in on how its done in a shop that takes anything and everything in...if you want me to stop then...too bad..  if 2 people learn anything from what i do then i'm a happy zap!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Could you just hardsurface those and then machine it down, that would maybe help it wear a little bit longer????......Just an idear.Miller blue star 2eLincoln 175
Reply:Originally Posted by FearcityINCCould you just hardsurface those and then machine it down, that would maybe help it wear a little bit longer????......Just an idear.
GMT+8, 2025-12-21 14:51 , Processed in 0.097991 second(s), 18 queries .
