230v tool in the home
发表于 2021-9-1 00:38:13 | 显示全部楼层 |阅读模式
Some welder are made to run at 230v.  However the household standard electrical wall outlet is only 110v.  how would one go about using 230v tools such as mig welder , plasma cutters in the home ?  I heard someone mentioned using the stove/oven electrical socket but I don't understand how.  Can someone please comment on this topic.? Thanks
Reply:(2) 110's make 220. Not to be rude, but if you dont even know what your stove is pulling you need to call in a sparky(electrican) to set you up. Electric is deadly! I wouldnt want that for you.
Reply:Throne7....Do a basic search in the search box with some of the key words that you have interest in. that will give you some base knowledge of what you are asking. then with the answers you receive from your questions you will be able to relate to with a little more understanding. It helps alot thats what i do
Reply:basic ideerA 50amp Stove receptacle is exactly like the one on the left.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by jreynoldswelding(2) 110's make 220. Not to be rude, but if you dont even know what your stove is pulling you need to call in a sparky(electrican) to set you up. Electric is deadly! I wouldnt want that for you.
Reply:Yes, (2) 110's outlets will give you 220. As long as your machine is single phase you should be fine. Google is a great place for you to start. I dont use any machines that run off 220, all my welders are engine driven. My hot tub however is 220V, and when I hooked it up I ran from a 30 amp in the box to the gfi and then a pigtail to the tub, That outlet will also run a 220 buzzbox welder. Hope this helps.
Reply:throne,Nobody's steering you wrong, but some of the details may have been left out.Homes in the US have their 'usual' outlets at and configured for 110-115-120V (in this case, all three of those numbers are pretty much the 'same').But some big electrical items in the house may be wired for 220-230-240V (again, those three numbers are the 'same').  Big things like an electric stove, an electric water heater, a hot tub/spa, a welder  , etc.How can that be, you ask?Simple.  The power coming into the house is actually 240V (I'll skip the three number call-outs from here on).  But that 240V is between the two "hot" wires.  Each of those hot wires is 120V compared to the "neutral" wire.  So two hot wires = 240V, one hot wire and the neutral wire = 120V.http://en.wikipedia.org/wiki/Split_phase  The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by jreynoldsweldingYes, (2) 110's outlets will give you 220. As long as your machine is single phase you should be fine. Google is a great place for you to start. I dont use any machines that run off 220, all my welders are engine driven. My hot tub however is 220V, and when I hooked it up I ran from a 30 amp in the box to the gfi and then a pigtail to the tub, That outlet will also run a 220 buzzbox welder. Hope this helps.
Reply:Originally Posted by MoonRisethrone,Nobody's steering you wrong, but some of the details may have been left out.Homes in the US have their 'usual' outlets at and configured for 110-115-120V (in this case, all three of those numbers are pretty much the 'same').But some big electrical items in the house may be wired for 220-230-240V (again, those three numbers are the 'same').  Big things like an electric stove, an electric water heater, a hot tub/spa, a welder  , etc.How can that be, you ask?Simple.  The power coming into the house is actually 240V (I'll skip the three number call-outs from here on).  But that 240V is between the two "hot" wires.  Each of those hot wires is 120V compared to the "neutral" wire.  So two hot wires = 240V, one hot wire and the neutral wire = 120V.http://en.wikipedia.org/wiki/Split_phase
Reply:Engine-driven welders are generally used when electric power is not available for arc welding. Usually these are outdoor applications, major plant shutdowns. When operating engine-driven welders use in large spaces with good ventilation.This is just 1 of the many examples: Attached ImagesLast edited by jreynoldswelding; 01-22-2010 at 02:47 PM.
Reply:A buzzbox is just a term for 1 or the many 220 stick welders. The most common is the lincoln ac-225 AKA tombstone.Again this is just 1 of the many: Attached Images
Reply:To figure out how many amps your stove outlet is good for, just check the rating on the circuit breaker. Most 240 recepticals are either 30 amp or 50amp. And take a close look at the plug on your stove, there are several configurations of plugs. Make sure you get the right one, and due to your inexperience on electrical matters, I would recomend consulting an electrician.Hope that helps some.
Reply:Hi Grimm1, thanks for the respond.  What did you mean by " plug on your stove" ?  The thing at the end of the wire that comes from the stove and plug into the outlet?
Reply:http://www.frentzandsons.com/Hardwar...nfiguratio.htmEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-21 14:48 , Processed in 0.093190 second(s), 18 queries .
