Drying Damp Welding Rod
发表于 2021-9-1 00:38:09 | 显示全部楼层 |阅读模式
I have a 50# box of 1/8" 7014 and it has gotten damp in storage, any way to dry this out and make it useful again?Or should I just throw it away?John
Reply:If you had a dry rod oven, I think you could dry them out. Although I am not 100% sure.
Reply:I was kind of thinking of putting them in the oven in the kicthen when the wife's out for the day.John
Reply:I guess it all depends how wet they got and what you will be using them for, With rods being so cheap I would toss them and get some fresh ones.
Reply:Not really wet, just kind of damp.I brought them in to a warm area from be out side in a shed, therefore they got damp from condensation.John
Reply:http://www.lincolnelectric.com/knowl...nt/storing.asp you might give this a readidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Here is one thread with some info on moisture in stick rods.http://weldingweb.com/vbb/showthread.php...ghlight=rutileYou will likely be fine to dry out this rod in the oven.  I don't think you what to cook them out absolutely dry, apparently non-low hydrogen rods need some moisture to function properly.  You might try baking a few at a given temperature and time, then try them to see how they function.  Maybe you will determine what is too much drying versus not enough drying.  If they are too moist, the arc may be violent, and/or you may get porosilty.Let us know what you find.
Reply:Originally Posted by John RI was kind of thinking of putting them in the oven in the kicthen when the wife's out for the day.
Reply:Going to try a few and see what happens.How is the best way to store welding rods? I sure don't use them up fast enough to have fresh rods every time I weld.Does those plastic rod holders with a screw on cap keep them dry?John
Reply:ive done it on a propane grill just make something to keep em up outa the greasy grill should work finemiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:I keep mine in blue rod holders. They hold about 10lbs each and have an O ring for a seal and it keep the flux from getting beat off them. They work great for what I do.
Reply:Originally Posted by jreynoldsweldingI keep mine in blue rod holders. They hold about 10lbs each and have an O ring for a seal and it keep the flux from getting beat off them. They work great for what I do.
Reply:other than lohy, the original package should be ok.some rod, like red 6010, needs moisture.
Reply:Originally Posted by John RI have a 50# box of 1/8" 7014 and it has gotten damp in storage, any way to dry this out and make it useful again?Or should I just throw it away?
Reply:John R - If you check the specs, I think you'll find that to properly restore some electrodes, -that is to bring them back to spec from a wet condition- takes a long hot bake-out. Usually a restore is beyond the reach of a rod oven designed only to maintain electrode.Good Luck
GMT+8, 2025-12-21 14:47 , Processed in 0.093510 second(s), 18 queries .
