Video of a new type bender
发表于 2021-9-1 00:38:06 | 显示全部楼层 |阅读模式
I haven't seen this type of bender before, has anyone else? Maybe where to purchase one at.http://www.metacafe.com/watch/182347/bending_metal/kraftymate
Reply:Not exactly the same, but check out the benders at www.shopoutfitters.com.  Maybe they'll do what you want.  Some can be built yourself or cheaper copies found elsewhere, too.
Reply:check www.metalcraftusa.com  That picture sure looks like it.
Reply:definitely the same tool at the metalcraft site- I think they are made in Australia.The hossfeld bender has a die that works the same way, called a bulldozer die.But the hossfeld does about a million other things as well, while this one is pretty limited in the things it will do.Its kind a mini press brake turned on its side.The italians make a really cool power version of this, but it costs a bit more than $238.http://www.oceanmachinery.com/used-m...sed-bender.htm
Reply:i have one it works okChuckASME Pressure Vessel welder
Reply:It does seem to be a press brake style machine but it looks like its limited to small strips of thin guage metals. Maybe theres more to it that I don't see here.Bill
GMT+8, 2025-12-21 14:49 , Processed in 0.255201 second(s), 18 queries .
