Transporting painted panels?
发表于 2021-9-1 00:38:00 | 显示全部楼层 |阅读模式
How do you guys transport fence panels or gates once they are painted/powder coated?
Reply:I usually transport finished items standing up, strapped to the side of the truck, wrapped in shipping blankets, tarps or old bed spreads. I usually keep my eyes open for someone getting rid of these at yard sales/ flea markets. Old carpet works well also. I've also used Styrofoam insulation to cushion items if I've got some handy It makes a great barrier between the truck body and the items..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:This we wrapped while still hanging on the p-coat, bake oven racking, then transported. (Door and door framing was scheduled to be replaced,so no connection to door stud framing possible....and hadto offset railing line to the door frame.  No return on bottomstep leg, due to high traffic going past it, at right angles. Post gussetingdue to the above, and close edge distance of outer anchors toconcrete edge. Customer signed off in advance as to non-codeconformance. Foot plates, gussets, final fitting done on site, priorto p-coat & install.)http://weldingweb.com/attachment.php...1&d=1264645830http://weldingweb.com/attachment.php...1&d=1264646118 Attached ImagesBlackbird
Reply:I biult an A frame rack that sits in the truck bed or on the trailer.
Reply:Cardboard, moving blankets and bedspreads.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Same here- moving blankets, mostly.I bought a couple dozen of em for a big job about ten years ago, they still get used all the time.Buy a dozen at a time, they are only about ten bucks or so apiece.You will spend more than that, in time and money, fixing ONE scratched up fence panel.They will last a long time, if you dry em out when they get wet.
Reply:Cheep carpet remnants, plastic shrink wrap and that round split pipe insulation mainly.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Limit contact points between panels.  I use wood near welds points.
Reply:I usually haul standing up and use old blankets to pad with and tie down with Mule Tape.
Reply:built a rack that has reciever tubes that come out the pass side of truck then a upright rack that slides in to those taped carpet padding to those then place in between each sec of rail carpet padding  carpet i find is to abbrasive but the padding works wonders cut it up to 12x12 squares usualy can get the old stuff from a carpet store any more questions e- mail me at [email protected] or call 307-660-7920 i can send you some drawingsLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
GMT+8, 2025-12-21 14:47 , Processed in 0.086291 second(s), 18 queries .
