welding gate or other large width items
发表于 2021-9-1 00:37:59 | 显示全部楼层 |阅读模式
how do people put together a large area item like a gate and get it flat and not skewed/warped if I don't have a perfectly flat floor ?
Reply:Use pipe stands with two pieces of pipe going across them. Level the pipes and set your metal cross them. If you don't have pipe stands then make some. You will use them from now on.
Reply:I work off the floor when project demands it. My slab isn'tperfectly plumb, so I end up shimming my work in some spots. Hillbilly
Reply:Originally Posted by BobUse pipe stands with two pieces of pipe going across them. Level the pipes and set your metal cross them. If you don't have pipe stands then make some. You will use them from now on.
Reply:One also learns how to heat up stuff and cool it to take a warp out.QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:Originally Posted by hillbillyfabI work off the floor when project demands it. My slab isn'tperfectly plumb, so I end up shimming my work in some spots. Hillbilly
Reply:thanks, made a couple long horses like DSW's with 3 point feet and leveled them off with shims
GMT+8, 2025-12-21 15:09 , Processed in 0.095669 second(s), 18 queries .
