What works as an inexpensive welding blanket?
发表于 2021-9-1 00:37:51 | 显示全部楼层 |阅读模式
I buy these ones at the welding supply house, and  I think there must be something else I could use, that i have not yet tried? Maybe some of you  have  discovered  it?  Please share your discovery information!
Reply:I go to a awning manufacturer.  The sell a heavy flame resistant cotton fabric.  Here the material is called drab olive.  It look like military tent material. It is four feet wide.  It is highly water resistant, also.  Off the bolt it is about 4 dollars per yard.  I have used housing shingles to protect flooring when welding around posts.  It is often readily availiable at new construction sites.
Reply:harbor freight has some welding blankets that aren't too expensive.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:There's also something called duvetyne, which is commonly used in theater.  It's black denim fabric that's heavily treated with fire retardant.-Heath
GMT+8, 2025-12-21 14:47 , Processed in 0.088805 second(s), 18 queries .
