Miller Generweld 130
发表于 2021-9-1 00:37:51 | 显示全部楼层 |阅读模式
Looking for some info about the Generweld 130.Has anyone used one of these with the 240v output option? The manual says it will provide 3 kva. A graph in the manual shows amps for 120v settings, showing a max usable of about 30 amps. No graph for 240v though.I'm just wondering if this will get up to about 20 amps on 240v. Also I'm wondering if there is a way to wire it so it can provide 120v and 240v at the same time.EDIT: at the back of the manual it shows a 30 amp fuse I assume for 120v and a 10 amp fuse for 240v, so I guess that answers that question.Last edited by slagmatic; 01-31-2010 at 11:36 PM.
GMT+8, 2025-12-21 14:48 , Processed in 0.114144 second(s), 18 queries .
