Newbie Greg here with a quick question....
发表于 2021-9-1 00:37:50 | 显示全部楼层 |阅读模式
It's about my weld pack 100. I forgot but the man took off two wires off of the gas solenoid. I see on the circut board were they go.There is a spot that says H2 and H1 control. Does it matter which wire goes were or can I hook them up and just go. Appreciate all the help.Greg
Reply:I would just hook them up and go.  If it stays on when it's supposed to be off and vice-versa, then swap the wire positions.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Hey greg, pick your manual here; http://www.mylincolnelectric.com/Cat...ualsearch.aspxYou'll need the manual for a lot of little things anyway.
Reply:the solinoid has no polarity meaning that either wire can go in either spot.  it does not matter which way the current flows in the coil the result will be the same.  it will induce a magnetic feild the will open the valve.
Reply:i have the installation instructions for the weld pak 100mig conversion kit from 1/15/93 i can email you a copy
GMT+8, 2025-12-21 14:49 , Processed in 0.092830 second(s), 18 queries .
