hossfeld bender
发表于 2021-9-1 00:37:44 | 显示全部楼层 |阅读模式
anyone have any manuals for a hossfeld bender they can scan or copy. i will pay for their troubles.
Reply:You know you can just buy one from hossfeld. In fact, you can even buy a video of how to use it. http://www.hossfeldbender.com/Its probably around 20 bucks by now, but they are made pretty well- I have had a manual under my hossfeld on the dies for about 20 years now, and it hasnt fallen apart and you can still read it.
Reply:LETS SEE IF THIS WORKS Attached Imagesscn_20041119142509_001.pdf (128.7 KB, 1268 views)
Reply:trying to post more than one at a time Attached Imagesscn_20041119142306_001.pdf (40.3 KB, 535 views)
Reply:still cant figure it out Attached Imagesscn_20041119142316_001.pdf (134.9 KB, 465 views)
Reply:Oh well****12-13-14-15
Reply:attach this time Attached Imagesscn_20041119142323_001.pdf (113.9 KB, 464 views)
Reply:two more to follow Attached Imagesscn_20041119142331_001.pdf (123.0 KB, 331 views)
Reply:***************** Attached Imagesscn_20041119142450_001.pdf (130.5 KB, 272 views)
Reply:################# Attached Imagesscn_20041119142503_001.pdf (135.4 KB, 359 views)
Reply:do you have a  picture ot the square tube dies  in operation.
Reply:Thats not the manual- its just the catalog overview. The manual is something like 40 pages long, and it shows the setup for each type of bend, including which die to use where. I will try to post the page about square tubing. You need a separate die set for each size sq tube, and for each size radius, at a couple of hundred bucks a pop.Last edited by Ries; 11-19-2004 at 10:22 PM.
Reply:I just ordered the manual and parts and price list from Hossfeld $4.80 total. Ed ke6bnl
GMT+8, 2025-12-21 14:47 , Processed in 0.092801 second(s), 18 queries .
