Welds this A.M.
发表于 2021-9-1 00:37:43 | 显示全部楼层 |阅读模式
Well i got some more time in with the hobart..still playing with the gas mixer but the aluminum is coming along...Attachment 4633and heres some 304 stainless i was fooling around with...fusing 2 pcs together in a "t"the object to the left is a dime...how small can you go? Attachment 4634more fun monday......zap!Last edited by zapster; 12-27-2007 at 05:22 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:You're killing me. I can match you on stainless. But the aluminum is still treating me like a biotch.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11You're killing me. I can match you on stainless. But the aluminum is still treating me like a biotch.
Reply:nice weld especialy the first alu, alu is hard.!!how do you obtain those clean weld on stainless. When i do it the stainless begin to oxide a bit over the top. But When i brush it's ok underneat.thx
Reply:Originally Posted by alterednice weld especialy the first alu, alu is hard.!!how do you obtain those clean weld on stainless. When i do it the stainless begin to oxide a bit over the top. But When i brush it's ok underneat.thx
Reply:ahah thanks your tha manI use to weld with arc machine, it's pretty much put your rod on the plate and weld :P
Reply:here are a couple pics of some butt welded 1/16" aluminum using pure argon,  , 2nd pic is penetration side. I have found if  welding thicker pieces you can just use a 75Ar/25He mix from your local welding supply and it works quite well. Never found a need for any fancy mixerhowever I usually just use pure argon and just crank up the amperage on the syncrowave 500 I have access to when doing thicker stuff Attached ImagesLast edited by elderthewelder; 08-19-2006 at 06:31 PM.
Reply:Nice welds Zap!!...and Elder!! Here is some aluminum I did today. It's a bumper for a Yamaha Raptor 660. The material is 1"x .120" aluminum tubing and .125" plate.I used STRAIGHT ARGON (Zap!!...still haven't bought myself a mixer ), 4043 rod, and 2% Tungsten.I will be putting more pics of this in the "Projects" section... Attached Imageshttp://all-a-cart.comWelding Cart Kits and accessories
Reply:very nice elderthewelder!!!i'm impressed...nice work ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by ZTFabNice welds Zap!!...and Elder!! Here is some aluminum I did today. It's a bumper for a Yamaha Raptor 660. The material is 1"x .120" aluminum tubing and .125" plate.I used STRAIGHT ARGON (Zap!!...still haven't bought myself a mixer ), 4043 rod, and 2% Tungsten.I will be putting more pics of this in the "Projects" section...
Reply:My gawd. Those are some nice welds there guys. I would give my left -- Never mind. I would love to have the talant to weld like that! Great bit of work! PaulMiller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:Zap, what was the mix on the welds shown?DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Originally Posted by littlefuzzZap, what was the mix on the welds shown?
Reply:damn.... you guys are good. So whats the hand technic? I think thats what i have to keep practicing. Do you guys rest your hand down? how do you guys slide across the metel so precisly. Because aluminum you gotta be really really steady.... come on.. give me a clue...
Reply:Geez....how big is your ego zap..??  I'm impressed with your skill's like most other folks here....but are you teaching or are you struting..??
Reply:Originally Posted by IT-WelderGeez....how big is your ego zap..??  I'm impressed with your skill's like most other folks here....but are you teaching or are you struting..??
Reply:Originally Posted by zapsterahhh maybe a little of both...i sowwie ...zap!
Reply:i never indicated i'd stop but i'll keep my "big head" out of the clouds so others wont get a complex..... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:as long as your going to post pic and tell us how you did the welding leve you big head in the mix  ChuckASME Pressure Vessel welder
Reply:Originally Posted by Mustangousdamn.... you guys are good. So whats the hand technic? I think thats what i have to keep practicing. Do you guys rest your hand down? how do you guys slide across the metel so precisly. Because aluminum you gotta be really really steady.... come on.. give me a clue...
Reply:Originally Posted by Mustangous Yeah.. keep posting the pics, but tell us some pointers or technincs....
Reply:What welding machine are you guys using to put out these beautiful welds??
Reply:Originally Posted by MustangousWhat welding machine are you guys using to put out these beautiful welds??
Reply:Originally Posted by zapsteri never indicated i'd stop but i'll keep my "big head" out of the clouds so others wont get a complex..... ...zap!Originally Posted by MustangousWhat welding machine are you guys using to put out these beautiful welds??
Reply:Originally Posted by zapsteri'm using this as of now.....zap!
Reply:Originally Posted by zapsteri'm using this as of now..Attachment 4651...zap!
GMT+8, 2025-12-21 14:54 , Processed in 0.071664 second(s), 18 queries .
