Home made tubing notcher
发表于 2021-9-1 00:37:42 | 显示全部楼层 |阅读模式
Hi everyone. I just completed my tubing notcher. There was allot of machining and milling involved but the over all cost was less than $50. There are many good store bought ones out there but for the amount of pipe work I do I couldn't justify the cost of purchasing one so I'm hoping I can get by with this one. I just made the first cut with it and it worked perfectly.The main block has self lubricating bronze bushings so I think it should last for awhile but to be safe I put an oil hole in the top as well for added lubrication. One thing about making your own tools is if they break you can repair them easily. Here's a few pics of the completed task. Hope you all have a great day. PaulMiller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:Good looking notcher Paul,Looks like it gives a clean cut.What are you powering it with?.I really have to get myself a mill. Great job.Simonhttp://members.optusnet.com.au/~abba/index.html
Reply:Very cool 4shorts.  X2 on the "I need a mill" comment.
Reply:Thanks guys. The notcher will come in handy I'm sure but your right about a milling machine. It's hard to own a lathe with out having a mill. The mill I have is not an expensive one but for the projects I do It's good enough. The lathe is a 1979 Sofia but works flawlessly and I've owned it for many, many years. Simon the notcher is powered by a hand drill and It makes the cut very fast. PaulMiller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:Vey nice work. I have a similar Mill Drill at home with a vise much like the one you have. It really works well. Your notcher does a nice job.
Reply:Have you guys seen one that will do 2.5" pipe all the way up to 5" pipe? My dilema now is that I do everything by hand as I haven't seen a notcher able to do that large of tubing. Think you can build me one? John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneHave you guys seen one that will do 2.5" pipe all the way up to 5" pipe? My dilema now is that I do everything by hand as I haven't seen a notcher able to do that large of tubing. Think you can build me one?
Reply:Well, make me one up and I'll shoot you over some funds!  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneWell, make me one up and I'll shoot you over some funds!
Reply:very cool....I plan on building one soon to replace the ol joint jigger i have now...
Reply:Originally Posted by 4shortsJohn I would think if you need one that big using a hand drill to power it up would be tough. I bet one could be made with a 1 HP motor on the end of the shaft. If I could only retire, I would have so much more time to play with this stuff.
Reply:Very cool notcher. I need to make one too, but I don't have a mill. I do have an old Craftsman (Atlas) lathe, but I need to do some PM to it. That design sure is sweet. I'm sure it doesn't move or chatter. Looks very, very stable. Great job!
Reply:Put simple.... Outstanding work!
Reply:4shorts,you are making that dunebuggy project I have been putting off for 15 years a whole lot harder to push to the bottom of the pile of projects.  Great work.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by smithboy4shorts,you are making that dunebuggy project I have been putting off for 15 years a whole lot harder to push to the bottom of the pile of projects.  Great work.
Reply:nice job...interested in roll cage work?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Wicked looking notcher.  very neat, well thought out, great craftsmanship.
Reply:I'm intersted in a tubing notcher. 4shorts, Would you mind posting those pictures again ?
Reply:Yeah, what happened to the pics?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:the pics have gone Paul Creative metal Creative metal Facebook
Reply:No pictures.........kraftymate
Reply:looks like a hole in photobucket  gota leak  dude
Reply:Hi everyone. Been gone for a while so I didn't realize the pictures weren't there. Got most of them back. Enjoy. PaulMiller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:What would you charge to build another one for me or anyone else?Kraftymate
Reply:Originally Posted by KraftymateWhat would you charge to build another one for me or anyone else?Kraftymate4Shorts, Thanks, I understand cause I have the same problem, not enough time to make all the things I have plans for.If you could in your spare time time take some measurements that would go a long way in order for me to build my own.Thanks, kraftymate
Reply:Very nice job on the tube notcher 4shorts
Reply:Originally Posted by Kraftymate4Shorts, Thanks, I understand cause I have the same problem, not enough time to make all the things I have plans for.If you could in your spare time time take some measurements that would go a long way in order for me to build my own.Thanks, kraftymate
Reply:Originally Posted by teknitionVery nice job on the tube notcher 4shorts
Reply:Originally Posted by 4shortsI appreciate that! Hey I see your in Sarnia. Love that place. I was there in 2001 on the week of Sept.11th visiting a good friend of mine that runs a company called PSC Philip services. It's a tanker cleaning business. Lots of newfies out your way but don't know if that's a good thing! Thanks for the compliment on the knotcher. It works well and I'm happy with it. Paul
Reply:4shorts,Have you had time to get some measurements? Don't consider this any kind of pressure.kraftymate
Reply:Originally Posted by Kraftymate4shorts,Have you had time to get some measurements? Don't consider this any kind of pressure.kraftymate
Reply:4shorts, I very much appreciate the time you've taken.Thanks Again.  kraftymate
Reply:Originally Posted by 4shortsHi everyone. I just completed my tubing notcher. There was allot of machining and milling involved but the over all cost was less than $50. There are many good store bought ones out there but for the amount of pipe work I do I couldn't justify the cost of purchasing one so I'm hoping I can get by with this one. I just made the first cut with it and it worked perfectly.The main block has self lubricating bronze bushings so I think it should last for awhile but to be safe I put an oil hole in the top as well for added lubrication. One thing about making your own tools is if they break you can repair them easily. Here's a few pics of the completed task. Hope you all have a great day. Paul
Reply:how do you notch tubing by hand?
Reply:Originally Posted by cheesecliphow do you notch tubing by hand?
Reply:Originally Posted by jimmyhatOMG im making one of these i hope you're cool with me stealing your idea!Got to spend sometime at the buddies machine shop here!
Reply:that is freeking coolChuckASME Pressure Vessel welder
Reply:i no yours is powered by a drill but if you dont have a tubing notcher how do you do it?
Reply:Originally Posted by cheeseclipi no yours is powered by a drill but if you dont have a tubing notcher how do you do it?
GMT+8, 2025-12-21 14:48 , Processed in 0.093985 second(s), 18 queries .
