got any tips or suggestions for innershied NR232?
发表于 2021-9-1 00:37:38 | 显示全部楼层 |阅读模式
im welding on stiffeners/ gussets on the base of a monopole tower and using NR232 in .068 looking for any tips or suggestions
Reply:If you have enough welder power .072 runs better.   Don't bother running it on CC it will fight you all the way.   If you don't have a 300+ amp CV power source you need one.Don't try and weld like your using stick or any other wire.   for V-Up you need to point the electrode DOWN towards the puddle.   Watch your slag shelf,  never let it turn into a V ideally you want to keep it at a very shallow U shape.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-21 16:01 , Processed in 0.091452 second(s), 18 queries .
