I'm taking the Python off my feeder and putting it on my 350P. The 350P has a 10-pin connector, whereas the older XR and Cobramatic feeders my Python has been connected to have other connectors with different pinout and different number of pins. I intend to retrofit the feeder with a current model 10-pin receptacle to match the 350P at some later time so I can swap the torches back and forth at will, but that's a seperate issue. For now, I just want to get the 10-pin plug onto the Python.I have the wiring diagramed out for my Spoolmatic's 10-pin connector for the 350P and there are 8 wires and 8 pins used in the plug. My Python, however only has 7 wires, not 8. It is an MK model Python, not a Miller model. Not sure if that makes any difference.I know where all 7 of the wires go on the new plug, but what do I do about the missing 8th wire? On the Spoolmatic, it is connected to pin A and goes to the gun body (ground).On the Python, am I supposed to jumper the black, negative, wire from the motor (pin B) over to pin A? Or do I just leave it empty and hope it works? I haven't wired the plug yet.Does the metal wire conduit body provide the chassis ground between the Python and 350P instead of the 8th wire?Here is the pinout I have for the Python-Pin A- Brown (ground, to gun body), this is the missing wire!Pin B- Black (negative, to motor)Pin C- Red (positive, to motor)Pin D- Orange (trigger out)Pin G- Brown (trigger return)Pin E- Blue (potentiometer, cw)Pin F- Green (potentiometer, wiper)Pin H- White (potentiometer, com)Here is the pinout I have for my Spoolmatic-Pin A- Brown (ground, to gun body)Pin B- Black (negative, to motor)Pin C- Red (positive, to motor)Pin D- Green (trigger out)Pin G- Brown (trigger return)Pin E- Red (potentiometer, cw)Pin F- Black (potentiometer, wiper)Pin H- White (potentiometer, com)MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Ok, I got the answer over on Miller. Cruizer said the 8th wire is not a chassis ground, it's a voltage pickup wire and is not needed, so I will wire it with the 7 wires it has and call it good.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op |
