here some
发表于 2021-9-1 00:37:29 | 显示全部楼层 |阅读模式
of what i do at work i fit and welded this Attached ImagesChuckASME Pressure Vessel welder
Reply:That's a good looking set up chopper.What application is it for?, I see similar dairy wash & irrigation pumps both diesel and 415v driven.Simonhttp://members.optusnet.com.au/~abba/index.html
Reply:thanks it is two 800gpm 15 hp pumps for pumping heatreating oil we also made a 2000gal tank that it hooks to but i did not build it so i did not take any pic's of itChuckASME Pressure Vessel welder
Reply:you get all the fun jobs   i love stuff like that  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:no not realy the lead welder thinks this i over my head my boss say he knows i can do a better job that why he wount let me but some time he has to let me and i know what you mean that was fun to makeChuckASME Pressure Vessel welder
Reply:WHat about using them as turbochargers in a mustang'?? seem big enough
Reply:Those pumps look like the ones we have at our pump stations. I guess they are a basic style fluid pump.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Originally Posted by elvergonWHat about using them as turbochargers in a mustang'?? seem big enough
Reply:here's a little one Attached ImagesChuckASME Pressure Vessel welder
Reply:i got my start welding on some thing like that, except my welds were just to add a head to the test tank to accept the size pump we were testing at the time. we made turbine pumps there and my main job was the metal lathe and electro ballencing the turbines, what a pain in the but that was if you let it get away you would be chasing the wait around that stupid turbine for ever, grind a little, test, grind, test, grind, test.  but it was fun to cut up and weld on the test tank. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
GMT+8, 2025-12-21 16:02 , Processed in 0.086871 second(s), 18 queries .
