Aluminum Tank Fittings
发表于 2021-9-1 00:37:26 | 显示全部楼层 |阅读模式
I want to change some plumbing on my aluminum cooler tank for a Miller Dialarc HF. Would stainless steel fittings be good to use with the aluminum? Brass better? Carbon steel?Thanks,  AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Stainless is the best of the choices.
Reply:Thank youAlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
GMT+8, 2025-12-21 16:02 , Processed in 0.068351 second(s), 18 queries .
