Does this sound right?
发表于 2021-9-1 00:37:22 | 显示全部楼层 |阅读模式
I just called my local supplier and they wanted $242.50 for 40 feet of 2x2 box with a 3/16 wall thickness...  doesnt that seem a little steep?Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:This is from a Craigslist ad in the Detroit area.  I believe that 11 gage is about 1/8" so your 3/16" should be about 50% higher if it is $ per pound.1" x 1" x 24' - 14 gauge: $15.95 per stick 2" x 2" x 24' - 11 gauge: $45.50 per stick 2" x 2" x 24' - 14 gauge: $32.75 per stick 3" x 3" x 24' - 14 gauge: $51.00 per stick 4" x 4" x 24' - 11 gauge: $83.25 per stick 4" x 4" x 24' - 14 gauge: $58.50 per stick 2" x 1" x 24' - 14 gauge: $21.75 per stick http://detroit.craigslist.org/mcb/mat/1592811669.html
Reply:Found another craigslist ad, local to Detroit for reference.  Looks like arounf her you could buy the tubing you need for less than the $242 your supplier quoted:1x2x1/8th 24 ft. long-$22.00 2x2x1/8th 24 ft. long-$30.00 2x2x3/16th 24 ft. long-$32.00 2x5x3/16th 23 ft. long-$70.00 http://detroit.craigslist.org/okl/mat/1572323546.html
Reply:Ridiculous is the word I'd use.Not saying I know what it's worth right now, but that sucks.
Reply:~$90 a stick(24') here in Tampa for 2 x2 x.25"If you cannot convince them, confuse them.         Harry S Truman
Reply:2x2x3/16x20ft $43 next place $47 closest place $80 in mid LA. Go to yellow pages and call around.Peter
Reply:Holy crap!!Hey Mooney, what are you searching for in theese craigslist ads, i cant find anything in my area ive just been searching steel. im also checking out the yellow pages to make a few more calls tomorrow.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:40 foot should be about 175 lbs so you can go from there. Here that would be a pretty common size and doubtfull it it went for more than 80¢ a pound. Big and common usually mean lower costs. Maybe you folks have some big time taxes and other operating costs to factor in too tho. Some cities and counties can make it pretty difficult for a business to stay in business.
Reply:20' stick of 2x2x3/16 is about $40-$60 at the local suppliers around here.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The reason you were quoted such a rediculous price is because you are not a frequent and higher volume user.  If you start ordering tons of the stuff the price will drop in relation to volume and frequencey of purchase. Another thing is that i never purchase steel in any amount untill i contact at least 6 suppliers minimum.
Reply:watch outyou are gonna get pregnant
Reply:Be careful with the super cheep tube steel.  The local ornamental iron place has this Chinese tube steel that is absolute CRAP!  i bought one in a pinch once because they were close and my regular supplier wasn't.   Most HORRIBLE piece of quality control i have ever seen in a milled product.  it was a parallelogram it was bowed up in the middle it wasn't flat across any of the faces the welded seam was a joke.   all in all HORRIBLE.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:somebody simply made a mistake, bring it to there attention and the price will be less, if not thats highway robbery"Obstacles are those frightful things you see when you take your eyes off your goal"   -Henry Ford
Reply:Originally Posted by SilveradoI just called my local supplier and they wanted $242.50 for 40 feet of 2x2 box with a 3/16 wall thickness...  doesnt that seem a little steep?
GMT+8, 2025-12-21 16:02 , Processed in 0.093549 second(s), 18 queries .
