Lets Modify A Bulldozer Track Idler Wheel...
发表于 2021-9-1 00:37:18 | 显示全部楼层 |阅读模式
Heres a bulldozer track idler that a local recycle yard wants to have made into a cable guide roller..heres where the tacks go..root weld...root weld with the "halfs" all welded to size..more next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:stitch weld  or "walking the cup" as some call it..this is finished..(welding)..when its machined i'll post pics of it so you can see where the cables will ride..later......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:process, settings, consumable type???... YOU'RE KILLING ME?!?!?
Reply:Originally Posted by KRSprocess, settings, consumable type???... YOU'RE KILLING ME?!?!?
Reply:What is the insert made of??  A heavy wall pipe modified to the diameter or a second roller??  What about the shaft and bearings?  Were they extended or modified in some way?
Reply:How many tacks did you use? Did the tacks hold the heat distortion? was it all welded without stopping?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I'm wondering if the part is going to be machined after the fact, and if so, do you plan to anneal it?Last edited by halbritt; 09-15-2006 at 03:43 AM.-Heath
Reply:Originally Posted by lotechmanWhat is the insert made of??  A heavy wall pipe modified to the diameter or a second roller??  What about the shaft and bearings?  Were they extended or modified in some way?
Reply:Originally Posted by elvergonHow many tacks did you use? Did the tacks hold the heat distortion? was it all welded without stopping?
Reply:Originally Posted by halbrittI'm wondering if the part is going to be machined after the fact, and if so, do you plan to anneal it?
Reply:NICE WORK, Zapster but i thought i only got all the good jobs thats a pretty interesting one you got there i never get to tig weld as much as i,d like i,m always straped to a mig stick or fluxcored.
GMT+8, 2025-12-21 16:02 , Processed in 0.091019 second(s), 18 queries .
