Old trailer
发表于 2021-9-1 00:37:17 | 显示全部楼层 |阅读模式
I just picked up an old trailer for free and I wanted make it a little longer and wider Here's a few photos. What do you think can it be done. Or should I leave it alone.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:I don't think I'd bother making it any bigger, not for that axle, especially since you didn't do the first modifications.  Don't trust others' unknown work except for how it's been used/tested previously.I might use it as-is for small stuff and build/buy a bigger trailer for other stuff.
Reply:clean it up a bit  put a deck on it  use it /or sell,  if ya dont have one  it will pay for it-self just by the use you may get out of it. theres allways somebody looking for a low dollar trailer
Reply:If you sell it just make sure t is safe.Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Sell it, take te money and buy some steel and build one to your own specs!  You can probably break even and wind up with a trailer perfect for your needs!  I weld just to keep my snow plows ready for next Winter!
Reply:well you can see how the axel was widend befor so you could do that again if you wanted, it would depend on how much wait you want to put on it as to wether its a good idea or not to widen it again. i would add a solid pice of angle irn along the hole lingth if the axel to add some suport to it. or as said above clean it up put a nice coat of paint on it and sell it for the $$ needed to buy a new axel wheel setup and some steel to build another one. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:If it were my trailer I wouldn't bother with widening it but would lengthen it and move axle further back, But if you are set on widening it I would suggest starting from scratch.
Reply:I was doing some searching on line and trailer axles are not that expensive from what I have found online. I may do what was suggested and clean it up a bit and when finances are a little better build one a little bigger. I have been looking this trailer over and they don't seem difficult to make.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Try redneck trailer parts here is the link  http://www.redneck-trailer.com/
GMT+8, 2025-12-21 16:01 , Processed in 0.108591 second(s), 18 queries .
