square stock transformer?
发表于 2021-9-1 00:37:12 | 显示全部楼层 |阅读模式
i know most transformer cores are ferrite/Iron based but does anyone know if its possible to build a E I core from solid square stock?  Ive seen inductors this way but how well do they work.Realgear 140 MIGMore DeWalt tools that I prolly needDIY 160 amp 40 OCV MOT Stick Welder
Reply:Any iron may be used as a core. Some iron alloys are better suited because they have a lower permeability, low magnetic resistance. In the EI core the air gap left by closing the E core with the I core has high permeability [resistance] and the magnetic flux [current] would not circulate well. Using an EI core with each section alternated, the effects of the air gaps are minimized making for a more efficient transformer.  http://www.tpub.com/neets/book2/5c.htmhttp://en.wikipedia.org/wiki/Magnetic_corehttp://www.vias.org/eltransformers/l...rs_07b_17.html
Reply:thanksRealgear 140 MIGMore DeWalt tools that I prolly needDIY 160 amp 40 OCV MOT Stick Welder
Reply:E-core power transformers are usually laminated.  Each lamination is electrically isolated from its neighbor so the eddy current path is broken, increasing efficiency.Transit, you have it bas-ackwards--lower permeability means higher resistance to flux.Tim
GMT+8, 2025-12-21 16:41 , Processed in 0.071314 second(s), 18 queries .
