have a old school test coming up... they are not used much any more...any tips any one might have, i've been throwing fire 30+ years, never used one. thank you be blessed mp13the reason you don't like the bible, you old sinner, is becauseit knows all about you.a man can slip into hell with his hand on the door-knob of heaven.REPENTANCE is never too soon.
Reply:What position 2G, 5G 6G or 6GR? Is progression up or down? Will you be using E7018?
Reply:6g, 7018 1/16 land. i ran a few at the hall today went well.... if only my eyes would work right, what are ya going to do???????????? be blessed mp13the reason you don't like the bible, you old sinner, is becauseit knows all about you.a man can slip into hell with his hand on the door-knob of heaven.REPENTANCE is never too soon.
Reply:Use about 90% of maxium allowable amps for initial pass. Get rid of the land if allowed. There is no need for it when using a backing or "chill ring' and it can lead to a lack of fusion. After the initial pass, you should be able to run the rest of the test just like you have done in the pass. |
