Best way to cut?
发表于 2021-9-1 00:36:59 | 显示全部楼层 |阅读模式
I am  cutting mild and stainless steel tubing to make turbo pipes with.  What do you suggest to cut them with? Then they have to be tig welded.  I have a chop saw, but it very messy.  Alot of clean up as u can imagine.Thanks,Dave
Reply:I think a good band saw or a cold saw would be the ticket.My name's not Jim....
Reply:cold saws are always very nice. so are band saws.Can also be done with a plasma cutter.
Reply:You should give this bandsaw a look lathemaster.com/Benchtop%20Bandsaw.htm .  I've been quite pleased with mine and I've cut 2" solid round stock without a problem.
Reply:A band saw is great if you're patient.  A cold cut saw is very fast.  For pipes, one of the Evolution miter-type saws might be a very cost-effective way to go.Jack OlsenMy garage website
Reply:Cold cut saw would be my first choice, but your not going to drop the coin on one of those so I would look at a dry cut saw.Have we all gone mad?
GMT+8, 2025-12-21 16:30 , Processed in 0.095477 second(s), 18 queries .
