More heads
发表于 2021-9-1 00:36:54 | 显示全部楼层 |阅读模式
Lately thats all i've been doing...fixing broken and making new heads  but these were fun because i got to do them in the "up" position..front head got the "stitch" treatment on both sides while i just did fillett welds on the inners (both sides)fillett..stitch..heads..but i was having the "pop the breaker" syndrome again..untill i had had enough.. it only did it when i tapped the pedal very lightly...hmmmmmmmmtook the bottom off and found this...the nut had fallen off the screw and the allen screw was backing itself out and throwing the gear alignment all outta whack along with everything else.....and that was the whole problem...the rheostat was getting crooked while the pedal was getting pressed and making something weird go on inside it..i cant get it to pop the breaker anymore... so let that be a lesson to me and you..keep up with the everyday maintenence and things will be cool... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Sweet!   Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:And you didn´t have TIG from forever? Man....Your boss must be glad at you =) Nice to know about the breakerr My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:the nut had fallen off the screw and the allen screw was backing itself out and throwing the gear alignment all outta whack along with everything else.....and that was the whole problem...the rheostat was getting crooked while the pedal was getting pressed and making something weird go on inside it..i cant get it to pop the breaker anymore... so let that be a lesson to me and you..keep up with the everyday maintenence and things will be cool... ...zap![/QUOTE]Use threadlocker on the fix?
Reply:good work as allways ,and a loose nut is allways bad no matter what kind or were is at      ChuckASME Pressure Vessel welder
Reply:Originally Posted by Weldordiethe nut had fallen off the screw and the allen screw was backing itself out and throwing the gear alignment all outta whack along with everything else.....and that was the whole problem...the rheostat was getting crooked while the pedal was getting pressed and making something weird go on inside it..i cant get it to pop the breaker anymore... so let that be a lesson to me and you..keep up with the everyday maintenence and things will be cool... ...zap!
Reply:Loose nuts!!!  I know some myself.So, you fixed it by finding the loose nut and making sure it wasn't loose anymore....I can see that working in other areas were nuts can be a problem.Smithboy...if it ain't broke, you ain't tryin'.
Reply:I got a nut last night! heheheLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:allways a loose nut
GMT+8, 2025-12-21 16:30 , Processed in 0.092760 second(s), 18 queries .
