More of the same old thing..part 2
发表于 2021-9-1 00:36:54 | 显示全部楼层 |阅读模式
well gang..all that welding i did monday was for nothing..the company that owns the roller wanted the "welded up" side to be the same as the side i put the new journal inso back it came and i had to "work my majick" on it...not bad for 9 hrs so far....the usual deal..cut off bad end..make new journal..shrink fit..weld..re-machine..wooo hoooo!! bore..3.5" deep...bore size 3.420"roughed down journal..small end is finished for the bore...3.428"shrunk together... more next post...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:heres the welding operation...root pass 1..root pass 2..finish stitch weld..and heres the cool part..used this one tungestion from start to finish..without having to grind it once..what fun..and man was it hot... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice job as usual zap....I Bet it was hot....are you using water cooled torch? Nice welds!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:275 amps = watercooled all the way.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:wow, that's nice work***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:Acceptable as far as VT goes IMHO!!!   Did you use a positioner or did you just rotate the job on the table while welding it together? Respectfully,SSBN727  "Run Silent...  Run Deep!!!
GMT+8, 2025-12-21 16:29 , Processed in 0.089559 second(s), 18 queries .
