Mercury Outboard racing part
发表于 2021-9-1 00:36:52 | 显示全部楼层 |阅读模式
Just finished water cooling this filler block. Can't see all the work, but I milled trenches down the sides, added cross holes, made cover plates & pipe fitting ports, then welded it all up leak tight. This filler block connects the 2 stroke exhaust ports to the exhaust megaphones. Supposed to add a few H.P.to the 44 cube motor. Now I know why more people don't do this... took a couple solid days of work. Now I'm scrambling to get the motor together for October 21/22 racing. Attached Images
Reply:great job alanaker lots of work hope it makes those extra HP's for ya good luck at the races keep uss posted how you went Creative metal Creative metal Facebook
GMT+8, 2025-12-21 16:30 , Processed in 0.401109 second(s), 18 queries .
