machinist vice
发表于 2021-9-1 00:36:39 | 显示全部楼层 |阅读模式
well its not really a welding project, but zap said i should post up some pictures. My manufacturing teacher said i have about 4 hours of work left to do on this vice. most of it is done. just have to grind out the tramways. tolerance on this project was +/-.0002
Reply:Looks good, Aluminum?
Reply:look like it should ,is it O1 good jobChuckASME Pressure Vessel welder
Reply:surface ground s7 tool steel
Reply:Sweet! Reminds me of some of my earlie projects! Now add some 1-2-3 blocks, vee blocks, parallels...etc.....
Reply:I'm impressed.  Did you machine the jaws as one piece, then cut them.
Reply:sure did. i have 5 weeks of class left, and one more project. i forgot the name of it. it 2 inches wide and looks like a 123 block with a v oni the top and sides. i'll try and get some pictures next week when hopefully i'll have the rough shape cut in. i'll get some better pictures of the vice when its done(with a real camera, not a phone)
Reply:GREAT job my friend.. keep up the good work..somebody has to.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-21 16:45 , Processed in 0.140765 second(s), 18 queries .
