查看: 13|回复: 0
Blown up 8hp Honda air compressor engine case..
发表于 2021-9-1 00:36:39 | 显示全部楼层 |阅读模式
This is what i had waiting for me this A.M.seems to have snapped the connecting rod and broke the bottom of the casting..well the first operation is to get the die grinder out and the canning wax so you can groove out the broken areas..heres the result after grinding..first weld pass...(notice the crack going up the middle)after that grind it off and do it again..next post......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Heres the finished piece...after the outside was done one little pass was done on the inside...it held acetone after it cooled off so i really dont think it will leak oil..this was fun!by the way..heat..120 amps A.C.3/32 red end tungestionsmall cup38% helium 62% argonNO PRE HEATNO POST HEAT...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:cool zapChuckASME Pressure Vessel welder
Reply:well done nice job  looks like some of the frankinstines  i have done, will work till they throw a rod again job secerity i say  REV IT UP
Reply:Zap nice work. Let me ask a question and I'm not knocking your work when I ask. All of your other welds are usually so perfect what is the reason these don't look as perfect as the others??
Reply:Originally Posted by Robo48Zap nice work. Let me ask a question and I'm not knocking your work when I ask. All of your other welds are usually so perfect what is the reason these don't look as perfect as the others??
Reply:Nice Zap!Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Zap, Does the canning wax keep the aluminum from sticking in the burr bit or what? If so, I got to try that. HenryA bad welder makes a good grinderA grinder and paint makes a welder that ain't!If you can't put a good weld on it, put alot of weld on it!
Reply:Originally Posted by zapsterHeres the finished piece...after the outside was done one little pass was done on the inside...it held acetone after it cooled off so i really dont think it will leak oil..this was fun!by the way..heat..120 amps A.C.3/32 red end tungestionsmall cup38% helium 62% argonNO PRE HEATNO POST HEAT...zap!
Reply:Yepper, good old canning wax...except I buy the cheap bits and they don't last.  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:seems like cast just soaks the grease upDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Originally Posted by MNSTRBLDRZap, Does the canning wax keep the aluminum from sticking in the burr bit or what? If so, I got to try that. Henry
Reply:Originally Posted by gnm109Nice work. Did it warp any?
Reply:Originally Posted by zapsterits a dirty casting my friend..new billet aluminum is very easy..castings that have been exposed to oil and yuck over a few yrs..well they are a challenge...but can be done..in the end?you take what you get and like it  ...zap!
Reply:Originally Posted by zapstersure does!works wonders on carbide bits..sanding discs / belts..hacksaw blades..anything that gets "gummed up" with aluminum..clean up is easy..one acetone wipe and continue welding.....zap!
Reply:It is right in the supermarket, parifin wax. Check the baking isle.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Baking Isle, explains why I had never seen it before  Thanks though, I'll definitely check it out.
Reply:hahahaa - yes, it's in the baking aisle.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Any other good uses for the wax around the shop?DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Yepper, you can bring the wife or girlfriend in and "wax dat azz"...  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneYepper, you can bring the wife or girlfriend in and "wax dat azz"...
GMT+8, 2025-12-21 16:34 , Processed in 0.111052 second(s), 19 queries .
