im tig welding .063 aluminum need warping tips
发表于 2021-9-1 00:36:34 | 显示全部楼层 |阅读模式
like i said welding .063 with my miller dynasty 200 working grate but now i need to weld a run that is over 6 foot long and cant get it to not warp please help
Reply:i have to TIG at least a dozen or so automotive steel panels every year....and they have to be PERFECT.....so here's what i'd try..after all your taks are done , try running anywhere from 2-6 inches , wait 9 seconds or the lowest u can on your Post-Flow , then IMEDIATELY air-quench 40-80 psi for 10-20 seconds  , do over again and again.i know i could do it , just play with the #'s.  hope this helps.        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
GMT+8, 2025-12-21 17:59 , Processed in 0.177387 second(s), 18 queries .
