查看: 13|回复: 0
Concerns on new machine.
发表于 2021-9-1 00:36:24 | 显示全部楼层 |阅读模式
Recently I purchased a used Lincoln Weldanpower225 on a trailer. It seems to be a very nice machine. I want to place my Oxy/Ac tanks on it. My concern is that the welder runs on gas. I am so afraid of a spark getting to the gas tank. Is this normal?Also, what angle can I place my tanks at?
Reply:lingarner you should not worry to much about sparks.  most of the time you should be working far enough away where sparks wont be an issue.  Tanks should be standing vertical all the time but a slight angle would not hurt.  I have my tanks angled and i have never had a problem.  Acetylne is the tank that should be standing vertical, because there is the possibility that the acetone will leak out, when that happens you could get acetylne coming out in a liquid state which is very dangerous.
Reply:Acetylne is the tank that should be standing vertical, because there is the possibility that the acetone will leak out, when that happens you could get acetylne coming out in a liquid state which is very dangerous.
Reply:Don't know the chemistry of it all,Zap,but I think the acetone and porous filler in the tank absorb the acetylene under pressure. It then releases it as pressure drops.                     MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by mla2ofusDon't know the chemistry of it all,Zap,but I think the acetone and porous filler in the tank absorb the acetylene under pressure. It then releases it as pressure drops.                     Mike
Reply:Zap if that was sarcasm, it looks as if you were owned.
Reply:I think it was sarcasm. I also think he was owned as well. Sorry zap. I love ya bro. Now I am going to google it and see.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:In 1896 the French scientists Claude and Hess discovered a way to store and transport acetylene without the risk of explosion. This method is based on the fact that acetone can dissolve many times its own volume of acetylene. The French call acetylene dissolved in acetone acétylène-dissous. At a pressure of 10 atmosphere one liter of acetone dissolves approximately 250 liters of acetylene.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:What's for dinner Muffy....Tea and Crumpets?  I weld just to keep my snow plows ready for next Winter!
GMT+8, 2025-12-21 16:35 , Processed in 0.073634 second(s), 18 queries .
