dc grinder
发表于 2021-9-1 00:36:04 | 显示全部楼层 |阅读模式
looking for a dc grinder to run off a sa 200anyone got a favorite 4 1/2 DC?found a makita 9557pb online. says its "AC/DC switch for use with alternative power sources"that'll work huh?dave
Reply:Yep. Any brush type electric motor with a simple off-on switch will run on DC current. However you may have trouble with the switch.
Reply:Most of the smaller hp 4.5 dewalt grinders are AC/DC.  The high perfomance 4.5/5/6" ones are AC only.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
GMT+8, 2025-12-21 17:43 , Processed in 0.085665 second(s), 18 queries .
