square to bevel 3-g test
发表于 2021-9-1 00:36:02 | 显示全部楼层 |阅读模式
what would be the proper sequence for welding  a square to bevel 60 included angle 1/2 test plate? straight across or one side to the other , thanks, charleston,sc
Reply:With a backing plate? Weld the square side first, then the bevel side, run stringers as you will want fuse eveything completly with no voids.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by Doug247With a backing plate? Weld the square side first, then the bevel side, run stringers as you will want fuse eveything completly with no voids.
GMT+8, 2025-12-21 17:34 , Processed in 0.108262 second(s), 18 queries .
