Ok, so far we have a rough outline for an upcoming welding How to dvd, but I would welcome any suggestions or possible tweaks on the basic outline. Keep in mind this dvd is a how to on MIG Welding Thanks in advance!MIG Welding How To·Introduction What is MIG welding?oOther types of welding§Arc§Gas§Mig§Tig·Equipment Welder and accessories, grinders, files, metal preparation.·Safety Equipment Safety helmets, gloves, proper clothing.oHelmentsoShieldsoScreensoDistanceoGlovesoClothing such as jacketsoEar and neck ·Welder description Knowing your welder. 3 or single phase? ·What bottle size? Location of switches and safety devices.·Weld Wire - Based on your intended application, what size wire you need, oSteeloAluminumoFlux coated·Torch anatomy oTips,oNozzlesoLiners?·Location for welder·Basic setup for welding oInserting the bottleoFeeding the wire into the machineoTurn on the machine and gasoWire feedoGas flow , pressure and typeoAmp rating·Types of Metal that can be welded - Highlight the types of metal currently available and what types can be used with a MIG welder. ·Steel welding ·Aluminum welding·Intended Use What do you plan to weld? Where will you be located?·Setting up and jigging Setting up your work to be welded.·Techniques associated with MIG Welding What techniques can a beginner attempt? What should a beginning welder do to ensure good welds?·Warpage and direction of the warp as well as how to prevent the warpage.· Advanced Techniques Techniques for welders comfortable with welding that would like to try something a bit more advanced.·Stacking dimes advanced oDifferent Types or paths·Welding defects Problems and how to deal with them. ·Closing - Short Review of all topics discussed
Reply:I see you have safety equipment listed, but I think you could ad a little something about work place safety. I'm sure lots of people using this dvd will be welding in their garages. A little info on fire safety could be thrown in for good measure. Other than that, the information looks pretty good.
Reply:Definitely include safety for you and others. Couldn't stress fire safety enough, from previous experiences......
Reply:Originally Posted by DeadlinetvOk, so far we have a rough outline for an upcoming welding How to dvd, but I would welcome any suggestions or possible tweaks on the basic outline. Keep in mind this dvd is a how to on MIG Welding Thanks in advance!MIG Welding How To·Introduction What is MIG welding?oOther types of welding§Arc§Gas§Mig§Tig·Equipment Welder and accessories, grinders, files, metal preparation.·Safety Equipment Safety helmets, gloves, proper clothing.oHelmentsoShieldsoScreensoDistanceoGlovesoClothing such as jacketsoEar and neck ·Welder description Knowing your welder. 3 or single phase? ·What bottle size? Location of switches and safety devices.·Weld Wire - Based on your intended application, what size wire you need, oSteeloAluminumoFlux coated·Torch anatomy oTips,oNozzlesoLiners?·Location for welder·Basic setup for welding oInserting the bottleoFeeding the wire into the machineoTurn on the machine and gasoWire feedoGas flow , pressure and typeoAmp rating·Types of Metal that can be welded - Highlight the types of metal currently available and what types can be used with a MIG welder. ·Steel welding ·Aluminum welding·Intended Use What do you plan to weld? Where will you be located?·Setting up and jigging Setting up your work to be welded.·Techniques associated with MIG Welding What techniques can a beginner attempt? What should a beginning welder do to ensure good welds?·Warpage and direction of the warp as well as how to prevent the warpage.· Advanced Techniques Techniques for welders comfortable with welding that would like to try something a bit more advanced.·Stacking dimes advanced oDifferent Types or paths·Welding defects Problems and how to deal with them. ·Closing - Short Review of all topics discussed
Reply:Yea, I think you are right. We probably will in the end shorten everything to a small focused video on MIG, so as to not be too broad. And you know... those knock off helmets? :-D |
