welding technique question
发表于 2021-9-1 00:35:52 | 显示全部楼层 |阅读模式
Doing some sheetmetal work on an old mustang.  Learned allot about  heating, warping, blow-thru, etc.  I've gotten better, especially my confidence level, but there's one area that I find troublesome; butt welds.  Both sides of the sheetmetal has a tendancy to pull up through shrinking and contraction after it cools.  My welding is good, good penatration, minimal heat zone, but like clockwork the two pieces will warp just a little immediately adjacent the weld.   Often, I can't get behind the pieces to provide support or an opposing weld to anticipate shrinking.  I recently set a door gap on a quarter panel with a relief cut, welded, ground, looked great!  Then......    Sure, less than a 1/16" of bondo will cover the prob, but how do you prevent it in the beginning?
Reply:If you are using mig, slow down and stagger your weld. instead of doing a long pass, do  small tack about 1/4 inch and not allow the metal to get to hot.
Reply:high localized heat input, skip welding and tacking can help.  So can back welding.  The other big thing is preheating the whole area so there's no significant difference in temperature.
GMT+8, 2025-12-21 17:36 , Processed in 0.097691 second(s), 18 queries .
