new tig cart
发表于 2021-9-1 00:35:41 | 显示全部楼层 |阅读模式
Well as long as I had my camera out I snapped a couple of my tig cart in progress. Still need some brackets to hang the torch and ground clamp, some way to hold rods, etc....I went away from the chain idea and just made a loop from some 1/8" steel with my compact bender, welded it up a foot or so to hold onto the tank. - John Attached Images
Reply:Looks like your choice in lathe and air compressor are the same as mine.The cart looks good too.s.r.
Reply:Excellent choices Like my material storage system between the lathe and the compressor? That part could use some work !
GMT+8, 2025-12-21 17:41 , Processed in 0.089522 second(s), 18 queries .
