"Can you pleezze fix this??"
发表于 2021-9-1 00:35:36 | 显示全部楼层 |阅读模式
Todays fun..Log splitter control valve leverseems to be in two pieces...After much grinding ..cleaning...cleaning..cleaning.. (i had to wire brush and re-clean it after every tack..and weld was put down.. REALLY crappy casting)   here it is tacked..here it is fixed..(1.5 hrs)from the top..from the side..note the gas lenz and 1/16 tungestion..(100 amps)Castings can be a challenge..this is the first casting that "burned blue"..you had to see it as i was welding it to understand i guess..i did all the finish "grinding" with a die grinder..i get all the fun jobs... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Should have had a capitol P in pleeze. BTW Nice Job!!!DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Hey zap, in that amount of time you could have -almost- milled out a brandy-new one on your Bridgeport!Hmmmm, 1.5 man-hours x labor + overhead = ~$200 to fix it.the satisfaction knowing that you could and DID fix it = pricelessThe blue burning was maybe hydraulic oil in the casting pores?What filler alloy did you use?btw, good job (again).
Reply:What filler alloy did you use?
Reply:nice work but I have to agree with Moonrise.  that thing looks like it was designed to break.
Reply:Is that the splitter from the neighbors house?Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Originally Posted by drivesectorIs that the splitter from the neighbors house?
Reply:Zap I've come to the conclusion that there's nothing in this world you won't tackle. Seems the tough jobs are attracted to you. Nice bit of work there my friend. PaulMiller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:Originally Posted by 4shortsZap I've come to the conclusion that there's nothing in this world you won't tackle. Seems the tough jobs are attracted to you. Nice bit of work there my friend. Paul
GMT+8, 2025-12-21 17:39 , Processed in 0.091150 second(s), 18 queries .
