Welding to I-Beam
发表于 2021-9-1 00:35:28 | 显示全部楼层 |阅读模式
Newbie Question I cant find anywhere here.Looking to weld some angle to the flat face of an I-beam. The load would be minimual 100#, and little moment on the beam, but some concerns over code, due to the fact that the I-beam supports the roof. Any restrictions on welding to structural beam? Thanks,
Reply:The restriction that I always remember is never to weld across the face of the I-beam, due to the risk of forming cracks at a high stress point.   If you run a bead on the edge of the face, that is less likely to form a crack, minimizes the stress raiser.Obviously many things are just clamped to the I-beam.  An angle iron could have one clamp on each side, especially if the weight involved is not a lot.RichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
GMT+8, 2025-12-21 17:42 , Processed in 0.093953 second(s), 18 queries .
