would you buy these?
发表于 2021-9-1 00:35:27 | 显示全部楼层 |阅读模式
I was planning to make a HD work table someday.... but  I found these locally...  not sure what 1" plate goes for these days.... but I think this would be worth the money... ?probably cheaper than making one... Residual to my late dads business. Great for a heavy shop or welding etc it measures 57 x 30 x 34 with adjustable leg pads. The top is 1 inch steel. Some tapped holes in it. I'd guess it weighs over 500 lbs I have a shorter one also which is shown in the bottom pics. That one is 48 X 38. That one has some light rust that will sand out easy . Just repaint it. $250.00 Attached ImagesMiller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:those are niceUA Local 598
Reply:If it works for you then go for it. It looks good, obviously clean it up a little. Good find.
Reply:Would I buy those, in a heartbeat if both for 250$. I'm building my own table and at 36in by 48in I'm into it for 300$ and that's only with a 3/8in top plate which cost 155$ alone.Harold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Thanks for the input. I figured a 1" plate @ 57 x 30 x 34 would be close to $200.00the only downside is the guy has no way to load them onto my truck...I may have to go over there with the car trailer and winch them up...Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Originally Posted by PetronIf it works for you then go for it. It looks good. . .
Reply:if your in So Cal I'd be interested in one of those, I'd jump all over those, I just bought a 1/4" 4x8 sheet for a table for 220 bucks just the top! I'd like at least a 1/2" but a sheet of 1/2" goes for 400-600 bucks"Obstacles are those frightful things you see when you take your eyes off your goal"   -Henry Ford
Reply:I would definitely pay $250.00 (especially if it is for both!).P.S.  Your location says "under a rock".  Is that anywhere near Sachse, Texas?
Reply:I purchased a home made welding table from Craigslist.  It's heavy, very crudely made.  Cost me $60, but it had a 3/4" thick 2x3' top on it.  I'm making a new subframe for it right now, using the old table to work on.  The subframe will have wheels, and storage for grinder, vise, a pull out drawer for files and room for my welder.  Use a craigslist table for awhile, then figure out what features you need on your next table.  --zip
Reply:Yep.  I'm not sure what prices currently are, but I paid $300 for a 30"x60"x1" piece a few months back.  It weighed a little over 500 pounds, and was a pain in the neck to move around.I think those are a great deal.Jack OlsenMy garage website
Reply:I just got back from looking at the tables.The price was for each table.  Still a great deal in my opinion.. the pictures don't do justice. these are VERY heavy duty tables. the legs look to be around 1/4" steel. very well made.I put deposit on the large table in the picture. I will pick it up wednesday with my car trailer and winch. He has 3 tables left. the smaller one in the picture, another smaller table with wheels Barely visible in the bottom left picture.  and a very large table... I'd say roughly 6'x4' he wants $200-250 each.  they are all super heavy duty with 1" plate tops. the down side is, he has no way to load them onto a truck or trailer.  you will need a flatbed or a trailer with a winch... liftgate etc. the tables are in Bristol, CT.ask for Tom  860-282-2239Last edited by John T; 03-01-2010 at 01:25 PM.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:he has the last one on EBAY.good luck lifting it...  http://cgi.ebay.com/Heavy-Steel-Plat...item25593de302Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:What is shipping on 500 pounds to SoCal? I shouldn't wonder. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:No takers...he just Re-listed it for $100.00 http://cgi.ebay.com/ws/eBayISAPI.dll...:WNARL:US:1123Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
GMT+8, 2025-12-21 17:40 , Processed in 0.184504 second(s), 18 queries .
