any one know any thing about computer LED screens
发表于 2021-9-1 00:35:19 | 显示全部楼层 |阅读模式
lately my screen has started going realy dark for no reason, its not off just so dark you can barly see any thing?? turn it off and on again no change but if you unplug the power and then plug it back in its good to go again??? is it time for the scrap heap or is there a easy (cheap ) fix for it??? summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:could also be the video card in the computer itself..the 'puter at the shop overheated one day..now wherever you type..there is a picture..text of any kind..it leaves dark streaks across the screen...if we shut it off overnite its fine...untill it gets warmed up again..my cousin Al builds custom 'puters and says it definatly happens...if you can borrow a monitor then try a swap to see whats going on.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It may have a backlight that is starting to weaken.  Its probably some sorta flourescent tube thats reflected to the size of the screen.  Not real sure since I havent taken one of these apart yet.  Flourescents get dimmer over time.  Same with crt (tv tubes) for that matter.  Take the cover off and take a peak.  Youve got nothing to lose (well, maybe, if its the only one ya got).  If its soldered to the actual lcd panel or self contained,Here is a fella that repaired his...  yours will be slightly different, but will use a similar principle.http://www.inventgeek.com/Projects/B.../Overview.aspxVarious GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:i dont think its related to the computer, if i pull the power plug(to the screen only) and replug it in the screen lights up again.i do have one of the old type but no acces to another thin one like this one.i supose pulling it apart will do no harm at some point as its going black more often now, soon it will be only a mater of moments between blackouts i supose at thet point nothing realy to lose. i guess i better bring the old dinasore one in for a back up. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:reread that post a little closer, power save features on the screen maybe?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:I agree with Doolittle as well. It is probably the flourescent tube behind the front of the screen. If the inside of the tube is brownish then you need another backlight tube.Miller Synchrowave 180SDLincoln WeldPak 100HD w/gas conversionPowermate 230A AC Arc Welder circa 1980
Reply:if you tap the screen does the light flicker?  Thinking cold solderjoint or bad invertor board..  Ive had to repair these in the field for smaller screens.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:tapping has no efect on it, i'm going to try another power scorce and hope i get lucky... its on for about 10 or less minuits then off again if i pull the plug and plug it back in its right back on well for a few minuits any way . summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
GMT+8, 2025-12-21 18:04 , Processed in 0.070531 second(s), 18 queries .
