Is this enough gas?
发表于 2021-9-1 00:35:14 | 显示全部楼层 |阅读模式
I have to make about 4 to 5 welds on 2 inch outer diameter aluminum tubing using tig. its not very thick. Will this last me or not?thanks,Brent
Reply:Yup, easily.Have we all gone mad?
Reply:thanks,Just didnt want to waste my time today having to refill the tank, well not waste time but time i could use for other things.ill be sure not to turn up the flow to much.
Reply:If your using the large bottle with TIG, I would think you will be o.k., but I can't say for sure since I never run my bottle down below 200 psi before getting a refill. Looks like you have ~225 psi remaining."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:yeah i am using a pretty large bottle, dont remember how big it is off the top of my head. I usually get mine refilled around this low, but i have a guy that needs this aluminum tubing welded up today and thats all the welding i have to do.
GMT+8, 2025-12-21 18:05 , Processed in 0.070795 second(s), 18 queries .
