Water Cooled Drum
发表于 2021-9-1 00:35:09 | 显示全部楼层 |阅读模式
Havn't done any of these in awhile...but there was not alot of room between the drain hole and the tube..maybe 3/16"..when things are that close you just fuse it and do the root pass near the hole only..finish stitch pass..you stitch up to 1/4" away from the drain hole..and pick it back up 1/4" after..so if you find yourself in that situation now you know what to do.. I get all the fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:man talk about nice welds :-) i wish i could do that. what is that drum going to be used for?thanksJason
Reply:Looks like its off of a paving machine.Looks excellent and makes sense.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:What rod size 1/16th?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:yup..1/16" filler..and its used on a roofing shingle assy line...015 shrink fit..all that hot tar has to cool somehow.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:shrink fit you mean that the cylinder was heated then the end caps were put in right?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by Doolittleshrink fit you mean that the cylinder was heated then the end caps were put in right?
Reply:Nice job Zap...._________________Chris
Reply:Impressive as always Zap.SimonLabel EverythingMetal Fabrication - Welding Repairs - Wrought Iron - Sign Writing - Custom Decals.
Reply:Hey Zap..... Does this job specify TIG as the welding process? If not then why would you choose TIG over another process? I'm not knocking it , I'm just curious...._________________Chris
Reply:no it did'nt specify tig..but with only 3/16" between the drum and the hole.....that was our best bet for watertight construction..thats my story and i'm sticking to it!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterthats my story and i'm sticking to it!...zap!
GMT+8, 2025-12-21 18:06 , Processed in 0.065300 second(s), 18 queries .
