hurting steel
发表于 2021-9-1 00:35:08 | 显示全部楼层 |阅读模式
this a in between job we have going at work we own it and are fixing it when were quite or between jobs by the end most of the shop will of had a crack at it theres a heap of pics here http://www.geocities.com/wello_1/ there was to many to crowd the forum with I got a new camera so I went overboard a bit  Creative metal Creative metal Facebook
Reply:Geez, what happened to it?DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:it tipped over and as it was going the guy jump out of the truck and left the PTO going the ram kept pumpimg and that did most of the damage the trailer is only 10 mths old Creative metal Creative metal Facebook
Reply:I used to pull dump trailers like that when I was younger (still do it part-time). I never rolled one but have seen a couple go over. You have to be pretty level when dumping because if they lean too far they'll go over, the load can also stick in the nose and when the rest of the load breaks free the top of the trailer will sway a bit side to side and they can go over. Sometimes its just poor maintenance of the rear hinge pin, when the trailer goes up, all of the weight of the load and the box are resting on a 2" round shaft - if that breaks, it's definitely going over. Good luck with that one, it looks like alot of work!!!Sure, I can fix it... I got a welder!!!
Reply:Went to the site but none of the photos came up, just FYI...- John
Reply:thanks John I work on fixing it opps  Creative metal Creative metal Facebook
Reply:eek a few months ago we had a trailer where the guy went under a low uderpass and bam... no roof... that looks like a lot of work. I wish i could take pics at work.
Reply:I have been working on what I stuffed up will have the pics up later today  I hopeCreative metal Creative metal Facebook
Reply:crimsonb5421 try this site it should work http://www.members.optusnet.com.au/welo/between.htmlI have more pics to put up a little later but this will show were we are up to at the present 8hrs work so far and counting  Creative metal Creative metal Facebook
Reply:Wello Good luck on the trailer repair. Enjoyed the pictures, I do not know much trialers except to hook up and go down the road. Take care Work safe
GMT+8, 2025-12-21 18:06 , Processed in 0.095206 second(s), 18 queries .
