i have a weldenpower 125 stick welder/genarator for some reason i fire it up and it will run for about 30 45 secs then cuts off any ideas?
Reply:Could be thats the amount of fuel in the carburetor from the startup choke and the engine stops because the main jet circuit is not delivering fuel. Clean/rebuild the carb.
Reply:Sounds like a basic fuel problem such as what transit suggested. Check for a plugged fuel tank outlet/valve or clogged filter too.And check the oil level. 'Oil Gard' shut down (if so equipped) may be activating.Last edited by duaneb55; 03-27-2010 at 12:17 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks guys
