Same Stuff Diffrent Day..
发表于 2021-9-1 00:35:00 | 显示全部楼层 |阅读模式
I've said in the past if we get arms..cylinders etc. etc. that need to be rebuilt that we usually bore/sleeve the assy unless the customer wants the bores welded..In this case they want the bores welded..Arms..As per usual you have to clean off the grease/oil/yuck before you start..and do yourself a favor...Dont just clean the bores.. ..clean the whole thing..because you know as well as i do the second you have to move it YOU WILL find that blob of grease with your filler hand..glove..whatever and then you have another mess to clean up.. Cleaned bore.. Now what I like to do is weld a "ridge" around one side of the bore..gives you a good starting point..Then with the ridge side down you weld from the bottom to the top untill done..After that you do the ridge thing on the top and then its done with no "missed spots"...Note the size of the cup on the torch..I ground down the opening to "half way" so i can get the torch into bores that dont have much room to get into..but if you try to grind down a cup be warned..its not easy..And there you have it..Now just do it 3 more times... I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:WOW you really love that TIG machine..... how long did that take you?_________________Chris
Reply:Originally Posted by lorenzoWOW you really love that TIG machine..... how long did that take you?
Reply:Zap,       What are you using to grind your TIG cups?  I have had NO success even dressing up a chipped cup.
Reply:Originally Posted by MJDamianiZap,       What are you using to grind your TIG cups?  I have had NO success even dressing up a chipped cup.
Reply:thats a lot of cleaning and even more TIGing in 1.5, verry nice work. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
GMT+8, 2025-12-21 18:05 , Processed in 0.525542 second(s), 18 queries .
