shooting tower
发表于 2021-9-1 00:34:57 | 显示全部楼层 |阅读模式
Has anyone got a picture of a tower welded up for a shooting platform.I am interested in looking at construction so I can incorporate some strength with cross braces out of lighter steel.I do not want to risk safety when building.Any pics of ladder type stands with a platform would be ok also.
Reply:you should go to a sporting shop that sells that type of thing and bring a camera with ya, then go home and build it out of aluminum so its light.good luck summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:Thank you are exactly right about weight.However I am building this one to be permantly mounted to be a shooting platform for archery.So  this one will not be moved once it is erected like the portable ones that some move from spot to spot.I am guessing some landowners have built a permanent structure on there own land and then use it year to year with no intention of moving it around.Thanks for imfo.Gary
Reply:Don't know.  Out here in the wild West we walk to find our game.I've seen platforms on some hunting shows but I don't have first hand knowledge.Cabela's maybe?***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:Here are some pics of stands I have built over the years . They are made of pipe  and are made for rifle hunting, not much room to manuver a bow. They were built to be transported in a 4x6 ft. trailer 200 miles to where they are erected. Attached Images
Reply:There shouldn't be anything scientific about bracing or cross-bracing.  Just keep it uniform. If you absolutely have to have a pattern to go by, you might check out scaffolding like a brickmason uses.  They are braced with folding crossbraces on each side and braced every 6 feet or so of height.
Reply:Or.....
Reply:When bracing rule is the most vertical it is the most vertical strenght it will give...same horizontal...might sound n00b but just FYI...Best angle for me it would be 45º that gives the most strenght in both waysMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:If it is going to be permenant then be sure to use concrete footings. This will really secure it well. Also be sure to make your cross braces work in compression under twisting moments from both clockwise and counterclockwise twisting.I can explain this better with a diagram but I dont have one. Let me know if you need a better explanation.Grant
GMT+8, 2025-12-21 18:06 , Processed in 0.092836 second(s), 18 queries .
