Practice pays off .....finally!
发表于 2021-9-1 00:34:56 | 显示全部楼层 |阅读模式
Check out these stich welds and tell me what you think. Attached Images
Reply:Ithink I  have to stop giving my secrets away...  way to go!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks Zap,maybe i'll try to wrap that around some pipe and repost
Reply:Originally Posted by JLowderThanks Zap,maybe i'll try to wrap that around some pipe and repost
Reply:Wow..all I Can Say Is WowKISS...KEEP IT SAFE STUPID
Reply:looks nice, someday I'll pony up for a tig machine.***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:Nice job!!Did you use the pulse function on your TIG or continuous.Very nice welds. - Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Great job ! It looks like the belly of a snake.MJD
Reply:looks like pay day to me.good looking welds, did you say that had some thing to do with Practice. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:good looking welds ChuckASME Pressure Vessel welder
Reply:looks great, give Zap a run for his money DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:OK, I'll be -real- picky.Generally you seem to have a nice consistent weave pattern going on once you got going.  But in pic 017 in the last seven weaves your pattern and rhythm sort of faltered and lost consistency.  And your pattern varied  in size/spacing over the course of your weld, tight at the start and much looser towards the end.Also in pic 017, you have an ending crater.In pic 017, from about the 12 o'clock position  to the 10 o'clock position from the hole in the horizontal plate you seem to have some questionable toe wetting onto the horizontal plate.  Toe wetting to the vertical plate looks pretty consistent and even though.Did you have enough gas flow?  Because your rainbow colored and inconsistent oxidation pattern of the weld says your gas coverage may have been a little on the low side (or too high and you had swirling or turbulence).Section and etch the piece and let's see the penetration and fusion.It's a whole lot better looking than my welds!  Keep up the practice!
Reply:These were all continuous welds.Although I did use the pulse to get the feel for stich welding but once I got the concept I turned it off.These welds were made at about 125amps with about 15 cfh of straight argon.
Reply:Very nice, consistent weld, good shielding.
GMT+8, 2025-12-21 19:13 , Processed in 0.089948 second(s), 18 queries .
