Custom truck rack
发表于 2021-9-1 00:34:54 | 显示全部楼层 |阅读模式
Here is a custom rack that I build for a local demo company.... The oval cut outs are for LED stop,turn, tail lights as well as a set of LED clear back up lights... plus there is a plat on the top for the LED beacon. In the end it will coated with Rihno liner, stuff holds up very well. After seeing the rack in my truck I almost kept it but... I can always do another.http://i147.photobucket.com/albums/r...h/P1010030.jpghttp://i147.photobucket.com/albums/r...h/P1010028.jpgLast edited by lorenzo; 01-19-2007 at 07:49 PM._________________Chris
Reply:Looks GoodDrivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:nice  rack!!!  lolReally nice.....I was wondering what did you use for the LED holes.  I had a time doing a similar project one time. weld it like you own it
Reply:Looks goodStrive For Perfection
Reply:Originally Posted by lewraynice  rack!!!  lolReally nice.....I was wondering what did you use for the LED holes.  I had a time doing a similar project one time.
Reply:I get it now... thanks for the pics. weld it like you own it
Reply:Good Job man!trucks looks good too!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I like it!what year is the ford?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:My truck.... 1999 w/ the 7.3 Turbo.... when I bought it fuel was cheaper than gas... NOT ANYMORE    _________________Chris
Reply:I have the same thing!4x4 dump.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:looks niceDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:SweetBruce Nothing like setting yourself on fire, to warm you up on a cold day.A craftsman is someone that does a better job than anyone else thinks is necessary.
GMT+8, 2025-12-21 19:10 , Processed in 0.101660 second(s), 18 queries .
