Welding Honda Motor crankcase
发表于 2021-9-1 00:34:52 | 显示全部楼层 |阅读模式
Got a crack in a honda four stoke pump motor from my mistake. It is now leaking oil and wonder if I can weld it to stop the leak.
Reply:Probably.  My guess is that the engine is a cast aluminum, which can be TIG welded.  Posting a picture of the crack and surrounding area of the block would help us say for certain.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
GMT+8, 2025-12-21 19:11 , Processed in 0.118104 second(s), 18 queries .
