Tig welding pronblem
发表于 2021-9-1 00:34:50 | 显示全部楼层 |阅读模式
I have a Lincoln Square wave 175. Does not have much use, maybe 3 hours on it.While tig welding some 1/8" steel the torch started to arch in the middle of the weld, if that makes sense. I had a 1/16" tungsten rod and machine set at about 85-90 amps.More like the arch starter would kick in while welding. Machine is not over heating, at least the lite does not come on. Sometimes it will do 1 or 2,  1" passes before it starts arching.thanks
Reply:Check your pedal for dirty contact inside the pedal, also check the control cord connection.  Beyond that, you may have to take the machine into a Lincoln authorized repair shop for an inspection.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Do you mean that the welding arc stops and you are left with only a high frequency arc?  Are you welding with DCEN and HF arc starting, or is the HF set to continuous?
GMT+8, 2025-12-21 19:13 , Processed in 0.091910 second(s), 18 queries .
