anybody know what size connector i need
发表于 2021-9-1 00:34:48 | 显示全部楼层 |阅读模式
what is the proper size for the camlock  connector  (twist lock ) that plugs into the front of the welder, for the ground/ stinger....On a 1998 model Miller DX 200  I have been using my china cables that have a 35/50 MM end, but not sure if they are correct.....I have not made the cables yet but will probably be 4 or 2 whatever i have on hand...
Reply:NEMA  charthttp://www.nooutage.com/nema_configurations.htm
Reply:No, not that plug, I mean the Male camlock type of plug. like on the opposite end of the ground clamp cable,  or electrode....
Reply:You have the right cable connectors.
Reply:You need a pair of "Dinse Male, 0.505" O.D." connectors.  Welding Depot has them.  They are also available all over e-Bay.  Most local welding supplies will also have them.
Reply:Got Em,  fit much better than the 35-50 mm plugs i was using, thing is i sold the machine that the 35/50 came from so i had to let them go with it.....
GMT+8, 2025-12-21 19:12 , Processed in 0.092610 second(s), 18 queries .
